Hitch Mounted Mud Flaps
Old 03-02-2014 | 05:48 PM
Default Hitch Mounted Mud Flaps
Looking for something that fits a 2.5" hitch.
Found the following, any feedback?
Anyone use similar?
http://www.towtector.com/index.cfm/p...e=cat/cat7.htm
Pwraddr is offline
Old 03-02-2014 | 06:02 PM
http://www.rocktamers.com/
Drock78 is offline
Old 03-02-2014 | 06:07 PM
Originally Posted by Drock78
Looked at those but only says for 2" reciever, I use a 2.5". Also, the protection area is not as big as the ones I posted.
Any others?
Pwraddr is offline
Old 03-02-2014 | 07:03 PM
The Rock Tamers are now offered in 2.5". You can call and order them direct since they aren't in stores yet. I got mine in November. I called them at least once a year since 2008 asking for 2.5" mounts... They finally offer them but as you said, they don't cover as well as the bristles. I went with them anyways since I figured the bristles would always look dirty.
Scagburner is offline
Old 03-02-2014 | 07:12 PM
Thanks for that info! I will look into them a bit more....I think I like the bristles.
Let's see what others think.
Pwraddr is offline
Old 03-02-2014 | 08:39 PM
I've had the rock tamers for 3 years now, they do a great job. I had mine cut out to fit my 2.5 receiver.
SLOWRIDE-388 is offline
Old 03-02-2014 | 08:44 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I have a set of Rock Tamers that were setup for my SRW truck. I'd say they work well, but they are a giant heavy awkward PITA to keep around, install, and store.
I have the molded mudflaps on my DRW truck now, and extended them a bit lower with another mudflap attached inside of them. I'll probably replace them with something else this spring though.
Sydwayz is offline
Old 03-02-2014 | 09:13 PM
That was my next plan if they didn't get with the times and update to the 2.5" drawbars... My biggest problem was the stock exhaust on my 2008 Silverado. I needed to pull my new boat back from Northern Michigan in November so I had to hurry up and modify the right side flap. Since then, I changed the exhaust to 4" MBRP Stainless that exits more out the side. The replacement flap for the one I hacked up is about $30.
Attached Thumbnails Hitch Mounted Mud Flaps-img_20131119_205200811.jpg   Hitch Mounted Mud Flaps-img_20131119_205134832.jpg
Old 03-02-2014 | 09:23 PM
Anyone use similar?
If you are running a turned up diesel, the heat from the exhaust will melt the bristles
weekend@burnies is offline
Old 03-03-2014 | 09:25 AM
Tuned or not, the new diesel's exhaust is very hot now and our Rock Tamers flap on the exhaust side is warping a little.
TW720HVY is offline
