Oil change which pump too buy? >
Old 03-20-2014 | 08:47 PM
Default Oil change which pump too buy?
I went out tonight to change the oil in the motors and my and hand pump upright canister is junk. I would like to go to a electric one this time are they worth a hoot and which one and where?
nova26 is offline
Old 03-20-2014 | 09:00 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I have the Jabsco oil change pump setup. Has the reversible motor so once it sucks the oil out, I can just flip the switch and pump it out of the bucket into whatever Im using for disposal. It'll suck the oil out of the motor in under 30 seconds!
http://www.defender.com/product3.jsp...9116&id=122092
US1 Fountain is offline
My Buddy has the one from west marine, it pumps In/Out. Has 5 Gal Bucket. seems pretty good to me (Except you usually Get Reamed at west marine)
fastdonzi is offline
Old 03-20-2014 | 10:24 PM
Randy Nielsen's Avatar
I have a jabsco 5 gal bucket changer & it is always a pain trying to set it somewhere steady so I got a newer jabsco that is like a sealed gas jug, it sets in tighter spaces, doesn't leak, & will hold all the oil from both 10 qt pans in 1 shot. Bought it at Amazon. Randy
Randy Nielsen is offline
Old 03-20-2014 | 10:41 PM
BUP
Randy is the lay down model just as good for sucking oil out as the 5 gallon bucket unit from Jabsco ? I have used the 5 gal one for many years and hundred of hundreds of oil changes. I have never had a problem with that 5 gallon Jabsco unit, just changed the fuse twice and using a new impeller for it about every year to year and half.
Also the trick to make the 5 gallon bucket stable is set in a square box that just fits the bucket and you can push the drain hose down in the side of box upright so it does not drain the used oil all over the place. I learned my lesson about 20 years ago put that damn bucket in a square box.
BUP is offline
Old 03-20-2014 | 11:32 PM
LubeJobs42's Avatar
Did you get the oil hot? Very important for canister to work!!!
LubeJobs42 is offline
Old 03-21-2014 | 04:43 AM
I have an electric JabsCo That I Was Going To Put On Craigslist This Weekend. My motor is out so I'm adding the drain hose kit. If you're interested PM me. It's only been used twice.
Drock78 is offline
Old 03-21-2014 | 05:46 AM
Randy, I know this isn't the "pump method" but if you could get to the drain plugs I've installed a couple of those drain hoses that simply come out of the bilge drain plug. I can get the oil as hot as heck and then drain into a bucket. It is really slick and I know I'm getting a good drain.
3pointstar
3pointstar is offline
Old 03-21-2014 | 06:21 AM
I have the same one.. Works exactly as US1 Fountain described. Run the engine for 10-15 minutes and get the oil warm and it comes right out.. I added a 1/4" NPT x 1/2 hose barb fitting to the end so I can attach to my engine drain hoses.
HyFive578 is offline
Old 03-21-2014 | 07:43 AM
Simply the best unit out there ... Just don't bump switch in reverse on accident and think your going to plug it with your thumb I wont go into details ! LOL Yes sucks out under 30 sec.
oneanddone is offline
