Trim Pump QUIT
I was out on Sunday everything running fine, went into a restaurant for a burger, came out and the Bravo Drive wouldn't go up or down, both solenoids are clicking from all switches. I am thinking its a motor, is there anything I should check before I change the motor. Again the pumps were both working fine and they both were pretty even prior to this happening. Any direction would be greatly appreciated
I have had a similar thing happen to me. If the solenids are clicking it could be dirty brushes and commutators. I have disassembled the unit exposing the motor and cleaned up the copper with emerycloth, reassembled and had good luck, but only for a limited time (about a sezasons worth) In the end, I have to purchase a new pump motor.
Start at the battery, 'n work through the solenoids to the motor's connections,...
Both the positives, 'n especially the Grounds,... Both ends of the wires,...
Then slather Grease on 'em, to keep 'em corrosion free,...
