Short bus.. err I mean 4BUS >
Old 03-23-2014 | 07:00 PM
Lightbulb Short bus.. err I mean 4BUS
Lets try this again, I looked over my set up and I think the only way to get all the oil out is to let all the other lines drip back to the pan like Griff said.
Then hook up a vac pump to the line that goes to the bottom of the cooler. On mine its accessible at the top. All I`d need is an adapter to hook to my -10an line.
The box is a vacuum pump btw , I`m an awesome drawer
ICDEDPPL is offline
Old 03-23-2014 | 07:07 PM
thats some funny chit right there.i can see mr borgie,s blood pressure rising,lol.
mike tkach is offline
Old 03-23-2014 | 07:10 PM
Nice drawing.
MILD THUNDER is offline
Old 03-23-2014 | 07:22 PM
[ATTACH=CONFIG]520824[/ATTACH]
My turn
Old 03-23-2014 | 07:37 PM
Nah that's funny as hell! Lol
Borgie is offline
Old 03-23-2014 | 08:41 PM
You will want to lube those valves with sb's peanut oil
buck35 is offline
Old 03-23-2014 | 08:43 PM
Randy Nielsen's Avatar
ICDEDPPL, first of all NICE set up!! Second, all you really would need is the small hose that the Jabsco pumps come with that go in the dipstick tube, it should go right in the cooler line & would pull all the oil right out. Mild Thunders Y valve would be slick if mounted on the bottom & accessible. That could make for a 15 minute oil change start to finish even with a big offshore pan. Or did winter finally drive me insane? Randy
Randy Nielsen is offline
Old 03-23-2014 | 10:02 PM
I say just start the leave the engine running while sucking all the oil out. Once you see the oil psi gauge drop to 0, you should be good. Just to be sure, let it run for another couple minutes. Then refill
Old 03-23-2014 | 10:07 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
the deep is offline
Old 03-23-2014 | 10:20 PM
These avatars are getting dangerous, I was reading MT's comment while looking at the avatar & it made perfect sense!!
