Procharger setup Big block Looking to go back to stock. >
Old 05-25-2014 | 08:10 AM
Default Procharger setup Big block Looking to go back to stock.
As the title states.
I had the charger setup for last couple years and its honestly just WAY more than me and my family need.
Its the bigger kit with larger intercooler, I wanna say M3 been it has been a while and I will update post once i check. Intercooler was pressure tested last year and NO leaks.
I'm looking to trade back for stock parts. It has a MEFI 3 thats been flashed by Arizona speed upgraded map sensor 42LB injectors just flowed and cleaned.
I would be wanting to trade:
Supercharger kit
Ecu
wiring harness (the map sensor plug was changed rather not get into cutting and splicing for no reasons)
I would prefer local as we can just swap the parts. But can ship if needed.
I would need to keep my fuel pump and regulator unless your willing to give up all your stock fuel stuff as well.
As far as how much cash? Im just looking to get some offers plus go back to stock. Nothing wrong with the unit, it powered my boat well above speeds you need to go in a 24 foot boat
Mtuned is offline
Old 05-25-2014 | 10:00 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Very vague is yours a 502 or 454 And just what all do you need my friend is looking.John Sr
Fenderjack is offline
Old 05-25-2014 | 10:25 AM
I would assume a 502 since it is listed under "my boats" under his avatar.
Tom272Baja is offline
Old 05-25-2014 | 11:07 AM
Fenderjack's Avatar
Tom272 baja I'm not assuming could be anything. John Sr
Old 05-25-2014 | 11:56 AM
Tom please contact me [email protected]. I'm interested
a262carl is offline
Old 05-25-2014 | 03:36 PM
502 big block.
Mtuned is offline
Old 05-25-2014 | 03:38 PM
Basically I'm supercharged now and want the boat back to stock. Don't need 800hp to pull tube around the lake.
Mtuned is offline
Old 05-25-2014 | 03:41 PM
Watch "Baja H2X Mike Ford Racing Engine. M3 Procharger. …" on YouTube
Baja H2X Mike Ford Racing Engine. M3 Procharger. …: http://youtu.be/90vFgwKZw8c
That's a video of it idling. End of video has supercharger in it.ill have detailed pics soon.
Mtuned is offline
Old 05-25-2014 | 06:27 PM
800 horsepower....
mallatt442 is offline
Old 05-25-2014 | 06:32 PM
offthefront's Avatar
unless there's been work to the motor its not 800, more like 600hp tops .. The PC doesnt make it go too fast, your right hand does ...how much boost you running? increase the pulley size to back the boost down and just let run .....it will run for ever .....m
offthefront is offline
