Heat Alarm wire.. >
Heat Alarm wire..
Heat Alarm wire..
Old 06-07-2014 | 03:12 PM
Default Heat Alarm wire..
So I figured out that my boat the heat alarm isn't hooked up..and I found that out after looking down at my temp gauge hitting 230 degrees...I have a thunder bolt ignition...does anyone know the heat alarm wire color to hook up??
stlliberator is offline
Old 06-07-2014 | 09:47 PM
I assume you mean the high water temp alarm????
There is a Merc alarm sender that installs in the intake. Then the tan wire with blue stripe connects to the sender.
Griff is offline
