smoky diesel = dirty boat
Old 06-27-2014 | 01:45 PM
Default smoky diesel = dirty boat
hey guys,... any ideas or tips for keeping the soot of your boat and trailer. we just bought a dodge diesel with a 12 valve for a tow rig and its turned up and runs great, but everytime we pull with it the boat is covered in soot, and its a pain to get off!
what do some of you other diesel guys do?
cagedlx is offline
Old 06-27-2014 | 02:05 PM
tune it down so it's not blowing smoke. Sorry but I have my D-Max tuned but blowing a crap load of black smoke is just throwing $$ out the pipe.
MonkeySea2 is offline
Old 06-27-2014 | 03:09 PM
Big, long stack threw the box of the truck. Have the exit up out of the slip stream of the boat.
92nsx is offline
Old 06-27-2014 | 03:14 PM
I ran a stack on my 6.4...screw that..Went to a axle dump that shoots it straight down and also had the truck live tuned so is toesnt smoke like crazy...smoke does not = power...
MINK is offline
Old 06-27-2014 | 03:21 PM
A good turn down at the stock location does wonders. And when your not towing you can put black spots on the white lines.
beaver 3 is offline
Old 06-27-2014 | 06:49 PM
Having had a couple of diesel's-- Black smoke is not necessarily a good thing - back on to topic.
I've used Simple Green - to get the soot off-- Wet the surface and then spray on full strength. It should work.
Take care and please get your diesel looked at - it could be something as simple as a bad air filter.
3pointstar
3pointstar is offline
Old 06-28-2014 | 07:50 AM
Its a 12v 6bt they must be turned up a little to get out of their own way. And when you do they smoke. Its just how p pumped diesels run with a little fuel thrown at them.
beaver 3 is offline
Old 06-28-2014 | 12:18 PM
if you want to get rid of black smoke add more boost! Won't get rid if it but it will tame it down some..
FIXX is offline
Old 06-28-2014 | 12:32 PM
Plum_Crazy's Avatar
You don't say where your exhaust exits. If you have a stack, it's certainly gonna get all over the boat. My truck is deleted and tuned. You can see the tailpipe exits at about a 45 degree angle out the right rear side. I also run Rocktamer hitch mounted flaps when towing as well which I believe help deflect the soot. At most, I'll get some soot on the trailer tongue. Since I keep everything sprayed down after each use with Boat Candy spray wax, it wipes right off.
Plum_Crazy is offline
Old 06-29-2014 | 09:21 AM
My suggestion would be not to have the soot. A clean boat and a truck with burning all the fuel would be the set up I'd want for my tow rig.
TW720HVY is offline
