Qatar turbine to run T55
Old 07-01-2014 | 09:24 PM
Default Qatar turbine to run T55
Courtesy of Hammer Down Boating:
https://www.facebook.com/HammerDownB..._t=photo_reply
This changes the whole game. If this thing stays together they will wipe the floor with the competition in SBI.
foxbat is offline
Old 07-02-2014 | 12:13 AM
It's unmatched HP, for sure!
Donzi ZX is offline
Old 07-02-2014 | 07:36 AM
very curious to see the impact 6000 hp has on ul and turbine class.
foxbat is offline
Old 07-02-2014 | 11:25 AM
ItsPeanut's Avatar
Just when the UL class was getting good the sheik goes big because he's tired of losing.
ItsPeanut is offline
Old 07-02-2014 | 09:23 PM
Well, can't say I blame him...if I had the $$ I'd probably use it to beat the competition, and take the crown. For years, the old Geico mystic did the same.
foxbat is offline
Old 07-02-2014 | 11:59 PM
Exactly. And if you're running a turbine the T55s are the package to dominate!
Donzi ZX is offline
Old 07-03-2014 | 01:04 AM
Comanche3Six's Avatar
A Beast!
Comanche3Six is offline
Old 07-03-2014 | 01:54 PM
What do you guys think are the odds of his driveline holding up to this much power over a race course, as compared to straight line runner like myway?
foxbat is offline
Old 07-03-2014 | 04:20 PM
I believe the key is to try to cutoff fuel to the turbines whenever the prop leaves the water, to save the driveshaft from snapping. The turbines don't spool down quickly enough by throttling alone. Let the turbines keep spinning, just with no power behind them.
Donzi ZX is offline
Old 07-03-2014 | 04:35 PM
So what is the fuel burn on 2 t55's at wide open??
phragle is offline
