SHOTGUN Exhaust
Old 08-22-2002 | 09:06 PM
rick32
Default SHOTGUN Exhaust
Does this change the sound of your engine......?
Rick32
Old 08-22-2002 | 09:09 PM
Payton's Avatar
Charter Member #927
12 guage is a little closer to stock than .410 or 20 guage.
Payton is offline
Old 08-23-2002 | 01:50 AM
If you're talking about Shotgun Mufflers, they will quiet the exhaust down quite a bit at idle and will quiet it somewhat through WOT depending on how you set them.
Griff is offline
Old 08-23-2002 | 08:00 AM
GEOO's Avatar
1975 X-18 Donzi, Arneson
I like them. They take the bite off the idle and help stop reversion issues.
GEOO is offline
Old 08-23-2002 | 08:20 AM
Dean Ferry's Avatar
Veteran: Air Force
LOVE EM!
They are mechnically simple, NO air pumps, solenoids, wiring, nothing to break. They seem to be well engineered, and I've run my pair for 75+ hours in Salt water with 0 problems.
Hope this helps,
MD
Dean Ferry is offline
Old 08-23-2002 | 09:07 AM
32storm's Avatar
Excellent product with simple design and installation. They do the trick at low RPMS's especially around the dock and in channels, etc. But, as you increase the RPM's, it basically riverts back to a full thru-hull situation. If you do a search on noise, you will find them mentioned in a number of threads.
32storm is offline
Old 08-23-2002 | 09:13 AM
JON242
Love mine too. A little quieter at idle and no RPM loss on top. The only thing I don't like is at idle they make a noise that kind of sounds like a valve tap as the metal shutter slams shut but its not noticable unless the engine hatch is up.
cstobe
02-22-2007 07:07 AM
Wardey
Extreme
24
01-10-2006 08:31 PM
Wardey
05-23-2005 11:53 AM
DYNAMOHUMM
04-23-2002 05:56 PM
