Aluminum Heads
Old 07-16-2014 | 08:03 PM
Default Aluminum Heads
Anyone put aluminum heads on there EFI 500HP's ? Wondering if it's worth it on my 32' Fever.
mikeyj08 is offline
Old 07-16-2014 | 08:04 PM
In fresh, yes..
commandersander is offline
Old 07-16-2014 | 10:43 PM
Probably save a hundred pounds or two...
Wes Burmark is offline
Old 07-17-2014 | 07:44 AM
SS930's Avatar
It's probably a great idea in a 32 Fountain, they need all the weight reduction towards the stern they can get.
SS930 is offline
Old 07-17-2014 | 07:53 AM
F-2 Speedy's Avatar
New 5-6 K cash and carry for two pair of good heads, do the cams at the same time if you do it, and stud kits and, and ,and
F-2 Speedy is offline
Old 07-17-2014 | 08:32 AM
SB
Unprotected aluminum can still be eaten away from electrolysis in fresh water. I'm on a 'certified for drinking water' lake and it happens. So.....order them hard anodized. Edelbrock and AFR can be ordered this way.
I still drain the motor after each day out just in case.
Add a set of cams, computer tune, and you can get to the 575-590hp level. With the heads too of course.
SB is offline
Old 07-17-2014 | 01:05 PM
Ateco Kit http://www.offshoreonly.com/classifi...o57996-en.html
Griff is offline
Old 07-17-2014 | 01:41 PM
Bob Madera @ Marine Kinetics also has a similar kit now available. It's heads, cam, porting, throttle body, etc. Think he teamed up and had Mark Boos tune it, etc. Sounds like a nice package. I was talking to him about it yesterday.
Jpzaluski is offline
Old 07-17-2014 | 05:03 PM
Mercathode system should be used on aluminum heads even n freshwater to mitigate electrolysis.
JRider is offline
Old 07-17-2014 | 06:03 PM
Thanks everyone! Anyone install that kit without pulling motors?
mikeyj08 is offline
