Looking at 29 Fever >
Looking at 29 Fever
Looking at 29 Fever
Old 09-02-2014 | 08:53 PM
Default Looking at 29 Fever
I am looking into buying a 1997 29 fever with a single 502. I have one lined up, just want to know if there is anything I should know.
I belive the owner says it runs about 65 with that motor, dont know what happened to the original motor.
I now own a 1988 checkmate convincer with a 598 ci making about 750 hp, the boat runs 80ish. Wondering
what the fountain will run.
I have a bravo x upper and a imco -2 lower, the fountain has a stock bravo set up, but it is counter ro.
Which set up would you guys run. I was told to make my set up a counter ro. all I have to do is change the way the shift cable works.
Just make it push instead of pull ? I hope to go for a test ride before this weekend, if all is good it will be mine.
Randy is offline
Old 09-03-2014 | 06:26 AM
Keep the fountain counter clockwise. That model is set up for that rotation. Clockwise prop will tilt the boat.
jtbooten is offline
