525efi rev limiter >
525efi rev limiter
525efi rev limiter
Old 09-14-2014 | 01:13 AM
fastlane40's Avatar
Default 525efi rev limiter
Can anyone tell me when the 525 is on the hard limiter of 5400 what change in exhaust note is there?
Any backfiring or popping?
fastlane40 is offline
Old 09-14-2014 | 02:38 AM
It will feel like an engine miss/stumble. It shouldn't pop or backfire
Griff is offline
Old 09-14-2014 | 05:32 AM
I get an early warning of a steady buzzing from the warning buzzer.
thirdchildhood is offline
Old 09-14-2014 | 05:56 AM
fastlane40's Avatar
So a 525 should not have a crack or exhaust note that is easily noticeable when on the rev limiter with open/dry exhaust?
Old 09-14-2014 | 12:12 PM
BUP
Run a scan of the engine. It will show up as an overspeed code and how many times it has happened. I would not keep bumping the engine off the rev limiter.
That is correct about hitting the rev limiter as it should feel like a miss / stumble Kind of like somewhat of an ignition component breaking up, then clears up when rpms are lowered.
BUP is offline
Old 09-14-2014 | 06:33 PM
Oh yes you can hear it in the exhaust , when you stay in it on the rev limiter
Bawana is offline
Old 09-15-2014 | 05:31 AM
fastlane40's Avatar
Okay so its normal to hear missing in the exhaust note.I do not think mine are noticeable at all but one of my competitors
is extremely cracking and popping.
Old 09-15-2014 | 01:22 PM
Normal? No. It will do that if you stay hard in the limiter, I don't think its good on the motor at any time to limit cylinders for any length of time. That is why merc has the audio alert that happens first, then if you stay in it it will crack & pop.
Bawana is offline
Old 09-15-2014 | 03:07 PM
fastlane40's Avatar
Thanks for clearing it up.That will be the difference.I don't stay on it.
