Go Back  Offshoreonly.com > Owners Forum > Eliminator
2000 33 eliminator hop >
Old 09-19-2014 | 06:09 PM
Default 2000 33 eliminator hop
Does anyone know what eliminator did to take away the hop on these boats. I already have a monster tab...
Eliminatorshane is offline
Old 09-19-2014 | 06:57 PM
Boxes?
dsmawd350 is offline
Old 09-19-2014 | 07:01 PM
I have boxes on it
Old 09-20-2014 | 02:24 PM
Registered User
What year? What power/prop? Hops at what speed and are u able to drive thru it?
shueman is offline
Old 09-20-2014 | 09:42 PM
99 33 Daytona. Twin 598 1100 hp. 1000 ft pounds at 4100. Dynoed.. 36 bravo 1 props not labbed. I haven't tried to drive thru it yet because for 80-95 so far it scares the sh?t out of us. It's bad....
Old 09-20-2014 | 09:44 PM
Has mt 4800 monster tab. Gets really squirrelly with tanks full too. Have boxes on it too.
Old 09-21-2014 | 10:29 AM
Registered User
I'll show the boyz the the shop and get their input...
shueman is offline
Old 09-22-2014 | 08:20 AM
5 blade cleaverish style props would most likely help. Hydromotive P5 would be a good choice. Bravo props do not impress me on most cats.
JRider is offline
Old 09-22-2014 | 10:26 AM
Are your props spinning in or out? Does anyone know if the Eliminators like the props turning in or out better?
FastVee is offline
Old 09-22-2014 | 01:03 PM
Registered User
What "type" of steps does your hull have? Hulls were re-designed around that time...
If the steps look "sawtooth", that is the older bottom...
If the steps look "square", that is after the re-do...
Re-tooling the bottom is the fix...you might also consider sponson tabs as an alternative...
INFO from Elim Shop production dept...
shueman is offline
