Trailer Box
I bolted some box tube aluminum to the bottom of my C-channels. The tool boxes are on either side of the winch stand, and are TOO LOW. You need to have them up high, the box opening needs to be at least 6" above the tops of the aluminum C-channel on your trailer.
bblythe has a nice setup on his Myco (with OverActive on it) with a tall box mounted high. If I was going to do it over again, I'd do it that way.
Too low:
They need to be about 6" higher minimum so I would never have a problem.
