Trailer Box
Old 09-28-2014 | 03:16 PM
Default Trailer Box
Looking to add a storage box on my aluminum Myco. Anyone know what they use, want higher quality. Also, how do they mount them?
Pwraddr is offline
Old 09-28-2014 | 05:37 PM
Relaxing's Avatar
I have one, you know the number.
Relaxing is offline
Old 09-30-2014 | 09:26 PM
On my Manning, they just welded some aluminum square tubing to the bottom of the frame (perpendicular). Then they thru-bolted an aluminum diamond plate tool box to it, works out just fine.
509 SC is offline
Old 10-01-2014 | 05:14 AM
Quinlan's Avatar
Same on my Manning but it fills up with water when we launch.
Quinlan is offline
Old 10-01-2014 | 08:25 PM
Mine is out of the water at launch, I often use it as my "step" to get on the trailer when pulling out. You must have to bury your trailer to get on and off.
509 SC is offline
Old 10-01-2014 | 09:40 PM
Sydwayz's Avatar
Forum Regulator
I bolted some box tube aluminum to the bottom of my C-channels. The tool boxes are on either side of the winch stand, and are TOO LOW. You need to have them up high, the box opening needs to be at least 6" above the tops of the aluminum C-channel on your trailer.
bblythe has a nice setup on his Myco (with OverActive on it) with a tall box mounted high. If I was going to do it over again, I'd do it that way.
Sydwayz is offline
Old 10-02-2014 | 10:50 AM
Maybe I don't have that issue because I have a tandam axle trailer. My box has never been in the water.
509 SC is offline
Old 10-02-2014 | 07:11 PM
Sydwayz's Avatar
Forum Regulator
It all depends on the ramp. Sometimes pending tide and angle into the water, I have to back in pretty far. I've had the rear axle pumpkin on my truck wet before.
Too low:
They need to be about 6" higher minimum so I would never have a problem.
Sydwayz is offline
Old 10-02-2014 | 08:29 PM
tcwcar's Avatar
Joe
[ATTACH=CONFIG]530270[/ATTACH] bought these at harbor freight, notched them to fit over the rail, painted them, and put diamond plate on top so I can stand on them....
tcwcar is offline
