ISKY Camshaft 396284/.294 >
Old 10-08-2014 | 01:34 PM
inspector747's Avatar
Default ISKY Camshaft 396284/.294
Camshaft is in great condition (Needs to be dry exhaust), Here are the specs
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 3,000-7,000
Intake Duration at 050 inch Lift: 238
Exhaust Duration at 050 inch Lift: 248
Duration at 050 inch Lift: 238 int./248 exh.
Advertised Intake Duration: 284
Advertised Exhaust Duration: 294
Advertised Duration: 284 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.578 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.608 in.
Valve Lift with Factory Rocker Arm Ratio: 0.578 int./0.608 exh.
Lobe Separation (degrees): 110
Computer-Controlled Compatible: No
Grind Number: RR-284/294
Valve Springs Required: Yes
Camshaft Manufacturers Description: High performance use/bracket racing; off-shore marine with I/O drive. Lopey idle. 2,500 stall. Up to 11:1 compression. 3.90-4.10 axle ratio. Up to 780 cfm carb.
Asking $250.00 +Ride
inspector747 is offline
Old 10-09-2014 | 09:37 AM
Bump
Borgie is offline
Old 10-10-2014 | 07:21 AM
Ttt
Old 10-11-2014 | 11:58 AM
Ttt
Old 10-13-2014 | 11:32 AM
Ttt
Old 10-25-2014 | 10:13 AM
Ttt
Old 10-25-2014 | 04:20 PM
what size block was this cam in
pantera 30 is offline
Old 10-25-2014 | 07:11 PM
