solid hub
Old 08-29-2002 | 03:22 PM
jafo272
Question solid hub
I'm running a 496 HO "425hp" and I keep cracking the flow-torque hub. I'm also running on the OHIO RIVER. Should I use the solid hub? I'm concerned with small trash harming the drive instead of the nylon hub. THANKS! for your comments
Old 08-29-2002 | 03:47 PM
mopower's Avatar
Toxic FORMULA
I run the Delaware river and wouldn't even THINK about a solid hub . Outdrives are a lot more expensive and time consuming to repair or replace .
mopower is offline
Old 08-29-2002 | 04:41 PM
jafo272
mopower what kinda HP and hub style are you using? I agree but I cracked the last flow-torque in one outing
nordic95
3
03-03-2011 07:21 PM
overdrive75
Prop Talk
7
10-02-2007 10:11 AM
Shah Mat
Prop Talk
2
06-26-2007 05:05 PM
Formula Outlaw
02-17-2004 10:09 PM
BAD-HABIT
3
08-23-2002 01:20 PM
