benefits of distributor-less ignition >
Old 12-14-2014 | 11:15 AM
Default benefits of distributor-less ignition
What's the gain here? Is coil on plug that much better?
Cole2534 is offline
Old 12-14-2014 | 11:29 AM
Its like sharing a girl with seven other guys... Its better to have her all to yourself....
Bawana is offline
Old 12-14-2014 | 11:43 AM
Ok. I'm building an engine on paper and am wondering if that's something to consider.
Cole2534 is offline
Old 12-14-2014 | 11:49 AM
Better? yes... Necessary? No... How much do you wanna spend? I would put my money on other upgrades..ie. rods, crank, heads, lifters, valves, push rods, springs........................................... ......
Bawana is offline
Old 12-14-2014 | 02:43 PM
Hmmm, I see.
Cole2534 is offline
Old 12-14-2014 | 04:15 PM
If you want to go crazy you can always put a mag on it...
Quick2500 is offline
Old 12-14-2014 | 05:03 PM
After all your other pieces are in place and you want totally stable timing control ,then consider crank triggered distributer-less ignition. I agree with Bawana on priorities
motor is offline
Old 12-14-2014 | 09:31 PM
I.think.the 496 gets it because it already has it .hall effect distributor guys have gone for the last bit of hp.by manipulating the trigger tin in the distributor to tailor spark event for each cylinder .
So what do you get the engine for Christmas,that already has everything ?
Coil on plug ignition system .
airjunky is offline
Save your money unless you're starting with it on the engine
sutphen 30 is offline
Old 12-15-2014 | 08:09 AM
depends on what you are trying to do....if you are running a "basic" ignition and a carb no, but if you are doing a MSD style and EFI I would say yes, the RF interferance that is flying around with the MSD box and some aftermarker EFI ECM's can drive you crazy, so at that point the LS coil packs, crank trigger, cam sensor deal is far better...Alex Haxby/Eddie Young can answer the fine points on this...
ezstriper is offline
