Another build dyno'd today. Whippled 509. >
Old 01-19-2015 | 07:48 PM
Default Another build dyno'd today. Whippled 509.
Another fun build that worked out real well. Mike Tkach built this one for a friend. It started out as a 502 Mag engine. Stripped down, bored to 509ci, flat top pistons installed, 2.3L carb'd whipple, with intercooler. . The owner of the engine wanted to stick with the GM rectangle ports. They did need some work, some seats were no good, etc. Anyhow, the shop went thru the heads, installed the larger 2.25 intakes, and did their valve job and bowl/pocket port cleanup. Bob M spec'd the cam for this build.
Mike and I went back and forth on this build, debating on what we thought it would make for power. Granted, him and I have never used one of these small single carb whipples before, and lets just say we underestimated it. Mike and I honestly thought this engine would maybe do around 650HP range. We were way off.
What really impressed me was the torque with this baby screw! Good lord. Anyhow, just thought I'd share it. Pretty basic build, nothing real trick. Bob nailed it on the cam as usual, and it just worked nicely.
Attached Thumbnails Another build dyno'd today. Whippled 509.-20150119_132628.jpg
MILD THUNDER is offline
Old 01-19-2015 | 08:19 PM
wow thats great what octane?
stimleck is offline
Old 01-19-2015 | 08:37 PM
Full Force's Avatar
Very impressive!!
Full Force is offline
Old 01-19-2015 | 08:44 PM
Makes me want to bolt a small whipple on my big block gas dually.
Old 01-19-2015 | 09:10 PM
Wow..... That's a ton of torque for only 7psi....... Great job!
tpabayflyer is offline
Old 01-19-2015 | 09:20 PM
From: East Texas Waterfront- running errands if anyone asks
How much of this Hp is motor? What boost out of the little whipple.
Flightplan is offline
Old 01-19-2015 | 09:34 PM
Is that torque for real? Holy S
Flightplan, boost is on the sheet....starts at 7 and goes down to 5.8 (third row from the right side)
TooLateVTEC is offline
Old 01-19-2015 | 09:38 PM
Thanks. Didnt look past Hp & torque
Old 01-19-2015 | 09:43 PM
SB
That 850 must have been struggling airflow wise.
SB is offline
Old 01-19-2015 | 09:49 PM
Nice results! apparently they are pricy for good reason. Wish I could drop mine off with you two!
buck35 is offline
