which one should I buy B-max or IMCO SC >
Old 09-04-2002 | 10:07 PM
cbudge
Default which one should I buy B-max or IMCO SC
Should I purchase IMCO SC or B-Max both sould like they work equally well. Some claim IMCO SC takes less power for the same duribility?
Old 09-04-2002 | 10:26 PM
thunderdan's Avatar
cbudge,
what type of boat and power are you running?
thunderdan is offline
Old 09-05-2002 | 10:44 AM
Offshore Addiction
unless your drag racing with tons of horsepower, definetly IMCO. we're a dealer,l et us know if you need help!!!!!
Old 09-05-2002 | 06:32 PM
Strip Poker 388's Avatar
Rob
Default b max
b max,talked to dean today said has the new foot ready,new torpedo design,imco prob cheaper,but maybe a little faster, i have had both feel free to e mail me if want
Strip Poker 388 is offline
Old 09-06-2002 | 07:42 PM
cbudge
I am going to run a quad whipple Paul Pfaff 1000 hp , 28 Howard Bullet V hull. can't decide between IMCO sc and b-max
Old 09-06-2002 | 09:37 PM
Official OSO boat whore
My dealer up here swears by the B-max. It's the only one with a 5" gear. Of course, it's that gear that slows it down. You realize that you are exceeding the capacity of the gimble assembly with that power. You should really be considering a speed master.
Cord is offline
Old 09-07-2002 | 11:49 AM
Rob
the imco is not going to handle 1000 hp, unless you baby it. the foot will be the weak link, the imco vert shaft is a torsion shaft that will flex a little instead of snaping, bmax upper with a imco foot?
Old 09-07-2002 | 12:19 PM
What part are you calling the foot?
cobra marty is offline
Old 09-07-2002 | 12:23 PM
Rob
the lower housing,lower half,prop shaft housing,what else do they call it?
Old 09-07-2002 | 12:55 PM
So which foot is the weak link? Stock? IMCO?
So the best would be the B-max upper and the IMCO lower?
Did I read that Bravo Shop has a new lower or is it mercruisers?
