Intake Manifold Gaskets >
Old 03-02-2015 | 01:32 PM
seafordguy's Avatar
Default Intake Manifold Gaskets
I have Weiand 6130 intake - Gen 6 502 with stock heads.
Which is the right gasket for my application?
Searching on here I found the Fel-Pro 1275S-3 which looks close, but I realized that it has a cutout in both the front and rear for the water passage and I don't believe I want that. http://www.jegs.com/i/Fel-Pro/375/1275S-3/10002/-1
What is the difference between that and the normal 1275? http://www.summitracing.com/parts/FEL-1275/
Is there a proper gasket that seals off the rear water passage?
Thanks,
Eric
seafordguy is offline
Old 03-02-2015 | 01:41 PM
I think you mean you want the water blocked in the rear.
Unlimited jd is offline
Old 03-02-2015 | 02:11 PM
seafordguy's Avatar
Yes - fixed............
Thank you...
Old 03-02-2015 | 04:02 PM
seafordguy's Avatar
EDIT - Looks like this is the one I want....
http://www.marineengineparts.com/eng...ines-only.html
Not sure why it is marked as "EFI Only"?!?!?!
Old 03-02-2015 | 04:54 PM
F-2 Speedy's Avatar
does your manifold have 6 or 8 holes per side for bolts
F-2 Speedy is online now
Old 03-02-2015 | 06:21 PM
seafordguy's Avatar
6......
Old 03-02-2015 | 06:37 PM
SB
#17341 has open exhaust crossovers.
#17342 has closed off exhaust crossovers (+ rear water ports) and it appears that has slight cutouts for the factory steel lifter valley tray.
SB is offline
Old 03-02-2015 | 06:41 PM
SB
It appears to have 8 per side.
SB is offline
Old 03-02-2015 | 07:34 PM
seafordguy's Avatar
Those 2 on the outside are not used on my current intake so it really is 6.
I think the 342 is the one I need.....
Old 03-02-2015 | 07:55 PM
Why Do you block off the back water passages?
Brandonb_05 is offline
