Lets finish the silly season ...454 question >
Old 03-17-2015 | 03:58 PM
Default Lets finish the silly season ...454 question
Im looking to make 500min, to 525 max hp and not eat bravos for lunch.
What I have is a gen6 block, mag crank and rods and holly efi. CAn this be done on reg rectangle heads with cam alone (say 52~5500 rpm) or will I need heads? which heads??
phragle is offline
Old 03-17-2015 | 05:16 PM
yes
sutphen 30 is offline
Old 03-17-2015 | 06:47 PM
blue thunder's Avatar
What do you have for exhaust?
blue thunder is offline
Old 03-17-2015 | 06:54 PM
Try a water/methanol injection while running 91 octane eth/meth blend, depending on the AFR.
sea6 is offline
Old 03-17-2015 | 06:56 PM
glassdave's Avatar
Neno the mind boggler
Rob has this EFI by the way with a MEFI 3 computer
http://www.jegs.com/i/Holley/510/550...TmMxoCyvzw_wcB
your gonna need exhaust . . . . Gils at the very least . . . . she gonna hafta breathe
08 OPA High Points Champion
glassdave is offline
Old 03-17-2015 | 07:07 PM
Exhaust is pretty much a given, but gills, emi's and sm's are in the swapshop all the time,
phragle is offline
Old 03-17-2015 | 07:29 PM
If Im going to go that far,why not set it up for say 20% model airplane fuel???
phragle is offline
Old 03-17-2015 | 07:43 PM
Got a set of cmi's I can cut you a deal on and deliver.
Unlimited jd is offline
Old 03-17-2015 | 08:10 PM
SB
That exact system or like that system ?
That part# has a 2000cfm throttle body. 1000cfm -1200cfm will be much easier to program on a 454 with that hp goal. IMHO.
Anyway Phragle - yeh, your hp is doable. Upper 5k rpm. Will be fine on the drive unless you drive the boat like you did when you raced offroad.
What compression are you comfortable with ? What octane can you get all the time ?
SB is offline
Old 03-17-2015 | 08:30 PM
My driving style..eh....... the efi was off of an innovation 600. Compression wise, Im on the conservative side, more like the "want to be safe if I end up with junk fuel somewhere side"....
The goal is a nice dependable motor that will push my little resin bucket mid 70's. with the 310 454 Im at 61 right now, Im thinking another 200 hp and 7/`800 rpm should do it...
phragle is offline
