33 outlaw throttle/shifter/indicator cables >
Old 03-28-2015 | 01:41 PM
Default 33 outlaw throttle/shifter/indicator cables
I want to replace all the cables on my boat and was wondering if anyone with a 33 outlaw has changed theirs and knows the sizes to all 8 cables. I know the codes are on them but I'm trying to order online without going over to the marina and uncovering and climbing in. It's a mission since I removed the swim platform and ladder.
ivanfuego is offline
Old 03-28-2015 | 08:26 PM
It would be in your best interest to just get the numbers from the original cables. You may find that you want to route them a little different, requiring a little longer or shorter cable. They may also have several feet of slack stuffed in the gunnel behind the upholstery that you can do away with by using the correct length cables. Just relaying some of the things that I've run into over the years.
Eddie
Young Performance is offline
Old 03-30-2015 | 09:07 AM
I would be interested in this as well. Just in case I ever need to replace one.
mittens is offline
Old 03-30-2015 | 09:17 AM
F-2 Speedy's Avatar
I did all my indicators, pretty sure they were
21' starbourd tab
24' starboard drive
26' port drive
28' port tab
F-2 Speedy is offline
Old 04-03-2015 | 06:42 PM
So I pulled my cables and here's the lengths. Maybe the next guy wanting to change his sees this.
Shifters: port 24'/starboard 21'
Throttles: port 23'/starboard 20'
Drives: port 26'/starboard 26'
Tabs: port 27'/starboard 21'
Don't know why the shifters are a foot longer than the throttles on both sides but they're all going longer so I can route them with the tabs I like the way those 2 arrived at the helm. Also gaffrig doesn't do odd numbers so I need all evens.
