Any feedback on these Slip on Flappers? >
Old 04-29-2015 | 09:04 AM
Default Any feedback on these Slip on Flappers?
I need to replace my exhaust flappers and came across these... anyone have any feedback? Think they are more/less restrictive?
http://www.cpperformance.com/p-22464...ess-steel.aspx
chrisf695 is offline
Old 04-29-2015 | 09:33 AM
Knot 4 Me's Avatar
I'm not a fan of those internal rubber flappers vs. stainless butterfly. Doesn't take many hours before they take a set pretty much open, unlike the external rubber flappers you see on straight cut tips..
Knot 4 Me is offline
Old 04-29-2015 | 10:13 AM
MnFastBoat's Avatar
Charter Member#157
Those would be a pain in the AZZ to change the flapper when burned out, and it WILL burn out!
How about a set of these? Much easier to replace the internal flap
http://teaguecustommarine.com/em0011...-assembly.html
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 04-29-2015 | 10:24 AM
I would just do the external rubber flappers but I have angle tips... I hear what your saying with the rubber internals though... I went through one metal in one season.
In my setup Mnfastboat it really wouldn't be that hard to change the flapper... its just pop off 4" hose and take the slip on off and its 2 screws. I really dont want to take off my current tip off right now to have a metal one welded on because the last owner 4200 the hell out of sealing up the tips... I would be tearing off gel for sure. The ones you linked above are for 4.5" too...
Old 04-29-2015 | 10:29 AM
Knot 4 Me's Avatar
If you go this route just be sure to check and change them often. Buddy hydrolocked a motor with tips that had a similar internal rubber flapper. Put the wrist pin thru the cylinder wall.
Old 04-29-2015 | 11:35 AM
All of mine were completely burned out when I bought our boat and I asked the same question here check it out:
http://www.offshoreonly.com/forums/d...ce-please.html
Diamond Dave is online now
Old 04-29-2015 | 12:09 PM
Thanks Dave! Im going to order one today. No welding sounds good to me and the price seems right too.
http://teaguecustommarine.com/em0011...pper-assy.html
