Hinges
Old 05-01-2015 | 04:27 PM
Question Hinges
Is it a double hinge (piano hinge) that allows a (let`s say a back seat cushion) to first pull out then lift and tilt?
Would this do it?
http://www.stagebox.com/index.php?ro...product_id=407
ICDEDPPL is offline
Old 05-01-2015 | 09:12 PM
weldcrane's Avatar
no it is not. the hinge pin has to travel forward to a stop then it can begin to lift up
weldcrane is offline
Old 05-02-2015 | 06:42 AM
Awash's Avatar
I keep thinking mine are like a Z and I think its these. Click on the blue hinge on the hunt hinge page and see if that isn't it.
http://www.hunthinges.com/products/s...eel-hinges.htm
http://www.ebay.com/itm/HUNTS-HINGES...-/400509464910
Awash is offline
Old 05-02-2015 | 08:27 AM
Yeah that`s a double hinge as I had originally thought .. maybe weldcrane can eleborate
ICDEDPPL is offline
Old 05-02-2015 | 09:04 AM
Formula uses that double hinge on all the storage seats. I will be out today an take a pic.
COOPS is offline
Old 05-02-2015 | 02:14 PM
Awash's Avatar
FWIW here is mine attached to the rear seat. I pull up in the front of the seat then pull out. Pretty much looks like a z I think you have to have the hinges like that if you use a double hinge with pins on same side (Like a U) it wont work..... Well I think any way. Maybe I'm over thinking this but best of luck on the project.
Awash is offline
Old 05-02-2015 | 05:44 PM
weldcrane's Avatar
What I'm talking about is not a piano hindge instead it is a slot which the pin is able to slide in when the actuator pushes forward the pin slides till it hits it's stop point then it ip outs up
Old 05-02-2015 | 05:53 PM
[ATTACH=CONFIG]540635[/ATTACH]
Here is formulas take on it
COOPS is offline
