7.4 lx efi falls on its face and hesitates >
Old 05-27-2015 | 05:55 AM
Default 7.4 lx efi falls on its face and hesitates
I've got a 7.4 lx efi the motor is tbi injected the problem I'm having with it is it falls on its fact on the top end. I have replaced cap, rotor, plugs, wires, checked fuel pressure 30psi under load, set timing at 8 degrees in base timing mode, replaced fuel water separator and still is doggy any thoughts?
Nick454 is offline
Old 05-27-2015 | 06:41 AM
I believe there is another filter by the throttle body also. Dump your separator in a coffee can (yes again) and see what you have.
JRider is offline
Old 05-27-2015 | 06:50 AM
No other fuel filters but I will drain the seporator and see what I get
Nick454 is offline
Old 05-28-2015 | 07:27 PM
Drained the seporator and hooked an aux tank up with fresh fuel no change
Nick454 is offline
Old 05-28-2015 | 07:32 PM
SB
REv limiter ?
Is this a new boat or engine to you ?
Describe "falls on it's face "
Overpropped ?
SB is offline
Old 05-28-2015 | 07:39 PM
No the boat is not over proped I'm running a 21p it will bog reving it in neutral
Nick454 is offline
Old 05-28-2015 | 07:41 PM
It will run fine till about 3/4 throttle anything after that it just bogs only get 4100 rpm on a good day the boat is a 22 scarab
Nick454 is offline
SB
Any trouble codes ?
What rpm did it run with the same prop when it ran well ?
SB is offline
Old 05-28-2015 | 07:46 PM
It never ran right from day one bought it last year towards the end of the season so didn't use it much
Nick454 is offline
Old 06-01-2015 | 11:13 AM
Anyone with any thoughts???
Nick454 is offline
