trim limit switch
Old 06-06-2015 | 08:28 PM
Default trim limit switch
Took my nova spyder to lake michigan for a sea trial today, I was pleased the engine ran great no leaks no drips the transom is water tight.got it on plane and went to adjust the trim no worky. Pulled the bolt out of the rams tied up the out drive to get home, found that the wires to the indicater and limit switches are rotted. Pulling a lower unit is as far as I have been with a I/O . Any idea what a boat shop would charge for this repair? Am I just being a *****? looks like if I got the bellhousing out maybe, will the gibal ring have come out to? I sure could use some good advice about now any help would be greatly appreciated. I'm not ticked off the least bit, I am convinced I got one hell of boat for 5 grand.
Nova Rob is offline
Old 06-06-2015 | 09:02 PM
Several youtube videos available that will familiarize you with procedure.
GLENAMY 242SS is offline
Old 06-06-2015 | 09:23 PM
thanks I will see what I can find
Nova Rob is offline
Old 06-07-2015 | 09:40 PM
Thanks for the answer that was a big help I could not stay in a boatlike this without the help of guys like you willing to help out ,, need to buy the socket for the hing pins and I'm on my way, not as bad as it first looked thanks glen amy 242 this ain't as bad as it first looked. Thanks
Nova Rob is offline
Old 06-08-2015 | 10:58 AM
I just reread this, are you saying it wouldn't go up at all? If so you're problem may be the trim pump solenoid. Although you do need new senders as well.
Fella on here sells a kit with all the necessary items to align engine coupler pull bearing etc,very reasonable. Good luck, ken
buck35 is offline
Old 06-08-2015 | 12:38 PM
I believe if it will trim "Down" and you can trim "Up" with the "Trailer" option (Not the Trim), you have a switch problem.
Old 06-08-2015 | 07:45 PM
Nothing, no up no down trailer switch doesn't work. I pulled the trim switch and jumped out the leads, nothing. Yes ken I think your rite I do suspect the solinoids as well, the sender leads are smoked sure would like to find the guy with the kit you read my mind I won't put the stern back together untill I m sure of alignment, gimble bearning and bellows u joints the whole deal. Thanks for the imfo fellas it all helps.
Nova Rob is offline
Old 06-08-2015 | 07:52 PM
Mine did the same last week. No up with trim switch because I changed to an hp transom assembly, and now the trailer up took a chit. Clicks but no motor kicking on. Had to jump it with a wire to get the drive up.
I'll dig into mine tomorrow and see if I can come up with a solution that may help you also.
ham_r_down01 is offline
Old 06-08-2015 | 08:22 PM
The solinoid on mine are not clicking so I'm sure to be dealing with more than one issue. I new going in ther would be issues its a1987. I'm realy jazzed abought this boat, lake michigan had soft 3 1/2 foot swells I could run 35-40 mph without needing a kidney belt, I thought she rode pretty good for a 26' hull I'm motivated il getter done.
Nova Rob is offline
Old 06-08-2015 | 10:07 PM
Check out all of the breakers , fuses and what not, I'll see if I can find the guy I bought my kit from. I believe that he's fairly local to you.
edit in, the guy I bought my stuff from is whoya on here, great deal !
buck35 is offline
