Misc Parts
Old 06-16-2015 | 08:52 AM
TomZ's Avatar
Default Misc Parts
Just some stuff that's hanging around and needs to go:
Small Block Chevy retrofit hydraulic roller...
Bob Madura grind that came out of my old 385. Only a few hours of runtime. Strong puller to 6200 RPM that got my 80 MPH in my old boat. Needs good heads and exhaust. $250
Billet core
LSA 112.2
Overlap 16.3
Intake
VO: 11.2 BTDC
Centerline: 108.2 ATDC
VC: 47.2 ABDC
Duration: [email protected]
Lobe lift: .380
Valve lift: .570 w/1.5 rocker
Exhaust
VO: 57.2 BBDC
Centerline: 116.2 BTDC
VC: 5.1 ATDC
Lobe lift: .371
Valve lift: .556 w/1.5 rocker
MSD 85551 Billet Distributor, locked advance. No weights but can be bought from MSD cheap. I installed a new pickup in early 2014, then pulled it because I needed an adjustable collar (this was in my S10). $100
Comp 7808-16 High Energy Pushrods, '87-up small block Chevy. Brand new, $40
Dart BBC valve covers, new but some stains on aluminum. Never on a running engine. They will not clear center-rise exhaust systems, $250
Circulation pump for MK IV, 454 Mag. Ran for four outings, then yanked engine due to transom issues. Basically new and includes the pulley. $75.
Mercruiser MK IV 454 Mag fuel pump and filter assembly. Maybe 10 hours on the pump at best. New stainless line between pump and filter, and includes line for Q-Jet carb. $75
Factory black MK IV valve covers, includes spreaders. $40
Everything is plus shipping from 23454. Pics will be sent upon request.
Thanks,
Tom
TomZ is offline
Old 07-10-2015 | 07:02 AM
Please send picts of fuel pump/filter to [email protected]
Ron Smith is offline
Old 07-16-2015 | 05:29 AM
The circulation pump, is it the water pump that mounts to the front of motor, or the raw water that mounts to bottom / front of motor?
going bigger is offline
Old 07-16-2015 | 07:21 AM
TomZ's Avatar
Been off the grid a little....
I'll get pics out as soon as I can.
Circulation pump... this is the cast iron pump that mounts to the front of the engine.
Thanks.
TomZ is offline
Old 07-16-2015 | 11:58 AM
if ron smith isn't doesn't want the fuel pump Im interested. send pictures to [email protected] thanks
Brandonb_05 is offline
