grease on you're balls?
Old 07-01-2015 | 02:04 PM
Default grease on you're balls?
Do you guys use anything on your trailer hitch ball?
Metal on metal dont sound to good and grease is a mess but you gotta do what you gotta do.
f_inscreenname is offline
Old 07-01-2015 | 02:07 PM
Tom A.'s Avatar
Every time I grease my balls, I get it all over my shorts!
No B.S. - I grease the hitch and then forget about it and some point down the road, lean into the bed of the truck straddling the hitch and wammo! Grease all over the front of my shorts!
Oh, and add "Do you grease your balls" to the list of sayings only a boater would not get offended by hearing!
Tom A. is offline
Old 07-01-2015 | 02:12 PM
Comanche3Six's Avatar
Lol!
Comanche3Six is offline
Old 07-01-2015 | 02:15 PM
use the old tennis ball trick
370ss500efi is offline
Old 07-01-2015 | 02:16 PM
SB
Just the front side.
On a serious note.
I do here and there, but more importantly I spray up into the trailer ball socket with Dupont Teflon spray or the likes. Keeps things from rusting and sticking...which is the main issue I see.....and will put some down on 'your balls' when attached.
SB is offline
Old 07-01-2015 | 02:22 PM
Whew, I thought I was the only one that lubed his balls..
Thanks guys..
Rattlesnake Jake is offline
Old 07-01-2015 | 02:33 PM
I use the white Teflon grease specially for balls...or trailer hitches, which ever. But to your point by the time it makes it to the front of your pants, it's black as coal....until the bloody shin leaks through too.
Hook'em is offline
Old 07-01-2015 | 02:50 PM
Dean Ferry's Avatar
Veteran: Air Force
both the ball and the receiver hitch get greased, and everyone is WARNED to watch out!
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 07-01-2015 | 02:52 PM
As SB pointed out, the lubrication coming out of the orifice has a natural tendency to migrate down onto the balls, thus keepinng them lubricated.
Wow, this sure isn't where I expected this thread to go. Are we still talking about trailer hitches? Is it time to start including discussions of Fountain beaks?
Budman II is offline
Old 07-01-2015 | 02:55 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
[ATTACH=CONFIG]542663[/ATTACH]
Attached Thumbnails grease on you're balls?-liquid_wrench_silicone_spray.jpg
Sydwayz is offline
