Wideband location ... >
Old 07-05-2015 | 12:23 PM
Default Wideband location ...
Happy 4th weekend folks.
Getting back into the boat after a little break. I have stainless marine manifolds for my gen 6 502.
I have mounted the sensors upright and towards end of risers. (Cut a large hole welded bung to bottom of riser and then patched water jacket. So it's sealed) how ever I'm running into reversion getting water on sensor at low speeds and idle and sensors don't last long.
If you have mounted one, where at?
Post up photos for refrence
Mtuned is offline
Old 07-05-2015 | 01:10 PM
Here is where mine is mounted. I have a decent cam, two seasons with no issues.
Quick2500 is offline
Old 07-05-2015 | 06:09 PM
Can you post a pic of the v band area?
I've used the Innovate heat sink when having the same issue.
Seems to have fixed the problem.
Jeff
hallj is offline
Old 07-06-2015 | 07:34 AM
I have two in my EMI risers with a healthy Bob Madera cam. One is for my Holley EFI and the other is for an Autometer stand-alone AFR gauge. 10.6:1, 548 cu. in.
Gimme Fuel is offline
Old 07-06-2015 | 02:53 PM
Don't have a pic, but its in a header primary about 8" from the flange (against the head) in a set of lightning headers.
Had a bung in the collector and the sensor would get wet and die running it hard, it was fine at idle/cruise.
TooLateVTEC is offline
Old 07-06-2015 | 03:35 PM
phughes69's Avatar
Jeff
Jeff I have the same heat sinks to try to make it harder for water to get to the sensor. My sensors are 3 " after the turbo's but my exhaust is straight out the back with the water dumping over the end of the pipe, ( I have dry exhaust). The distance between the sensors and the water outlet on the outside is about 28" I wasted a sensor 2 years ago, but Im not sure if it was from the engines running pig rich or water, All I know is it would not recalibrate. How far are you sensors to the point where water is mixed in with the exhaust?
phughes69 is offline
Old 07-06-2015 | 05:02 PM
Mine aren't more than 8" upstream of the water. I have a -6 fitting injecting water there. Just enough to keep the hose from burning. My cam is a 221/230 with 112 lobe sep.
hallj is offline
