30 outlaw twin 600sci Port engine wont start? Help! >
Old 07-21-2015 | 07:37 AM
Default 30 outlaw twin 600sci Port engine wont start? Help!
Whats up guys. So all the sudden my port engine wont fire. I got it to start when I started the starboard engine and gave it some revs but now it wont start at all. I checked the batteries and they are fine. Anyone have any ideas? Starter? Thanks
bavboym3 is offline
Old 07-21-2015 | 07:39 AM
are you saying it won,t crank over?
mike tkach is offline
Old 07-21-2015 | 07:48 AM
correct. It is not even trying at this point.
bavboym3 is offline
Old 07-21-2015 | 07:51 AM
VoodooRob's Avatar
Starter or hydro locked??? Batteries fully charged? Have you tried pulling spark plugs?
VoodooRob is offline
Old 07-21-2015 | 07:52 AM
F-2 Speedy's Avatar
kill switch
F-2 Speedy is offline
Old 07-21-2015 | 07:57 AM
when you engage the key do you hear a click? if yes it might be the starter slave solonoid,it is pretty common.
Old 07-21-2015 | 08:19 AM
mike whats the engine in your avatar?
stimleck is offline
Old 07-21-2015 | 08:24 AM
F-2 Speedy's Avatar
do you hear the fuel pump cycle when the key is turned to on
Old 07-21-2015 | 08:43 AM
Sydwayz's Avatar
Forum Regulator
Make sure you shifter for that side is in neutral. It may need a little jiggling to get there. You have a neutral safety switch, and sometimes they can get a little out of whack, or go bad completely.
Sydwayz is offline
Old 07-21-2015 | 08:44 AM
VoodooRob's Avatar
Originally Posted by 33outlawsst
kill switch
Forgot about this good point 33outlawsst, loose lanyards burned me a couple times at the ramp. Also sticks for the trans get "bumped" and engine wont start. Make sure your completely in neutral. Check the simple stuff, going for the more in depth stuff has always cost me time when it was an easy fix / brain fart.
