Best afr gauge and O2 sensor >
Old 08-04-2015 | 11:22 AM
Default Best afr gauge and O2 sensor
What is a good afr gauge and and O2 sensor kit?
Satisfaction is offline
Old 08-04-2015 | 03:15 PM
we run the NGK
ezstriper is offline
Old 08-04-2015 | 04:38 PM
Originally Posted by ezstriper
we run the NGK
Same here
MILD THUNDER is offline
Old 08-04-2015 | 09:12 PM
I noticed that those are not a gauge. Do you leave them installed all the time?
Also is it worth having a gauge on the dash or am I better off with a one time tune with the NGK?
Old 08-04-2015 | 11:06 PM
bck's Avatar
bck
Charter Member#568
Not sure if you're looking for a permanent installation or handheld for tuning, but I just ordered the Innovate handheld. If you wait a couple days I can let you know what I think of it.
Straight bottoms and flat decks
bck is offline
Old 08-04-2015 | 11:34 PM
I've been very happy with the MTX-L gauge / sensor kit from Innovate. I use it full time with the gauge mounted at the helm.
Trash is offline
Old 08-05-2015 | 07:08 AM
Good question. I've been thinking about changing out two gauges on my helm for AFRs. Gauges are cheap and lean is expensive.
Captain YARRR is offline
Old 08-05-2015 | 10:32 AM
I seen that the NGK is discontinued. this appears to be the replacement. Any feed back? Does it display the same results?
http://www.ebay.com/itm/Ballenger-Mo...item3ce6a3bd58
Old 08-05-2015 | 10:45 AM
I have had great luck with the Innovative MTX-L ... All in one kit priced reasonable. http://www.amazon.com/Innovate-Motor...novative+MTX-L
Eliminated572 is offline
Old 08-05-2015 | 08:36 PM
Innovate just came out with a dual channel AFR setup. One gauge that reads and displays two wide band sensors. Great space saver for those who want to monitor both exhaust banks.
Trash is offline
