350 magnum Engine head and cam upgrade
I have a 1993 Wellcraft 26' Nova Spyder with twin 350 Magnum engines. I have a set of Edelbrock Performer RPM heads # 60899 64cc 2.02"/ 1.60" valves. I was thinking about changing the heads, cam not sure of what grind and carb... What kind of horsepower upgrade could I expect don't want to waste time or money for little power, Has anyone had any luck with this. I really don't want to put stroker motors in it. Thanks for any help.
100hp per motor. 350hp is easy. Stock short block, Hot cam (or comp cams 218/224 112LSA HR) and Vortec heads (yours are similar power wise) have been done a bazillion times and make mid 300hp level.
Again, most ectend the inner pipes of their exhaust or go to aftermarket performance ones.
The other day went out on the boat had 4 adults and a full tank of gas 98 gallons on the boat GPS said 62 mph @ 4700 rpm it has 23 degree props is that normal and if so will they work with the upgraded engine.
