350 magnum Engine head and cam upgrade >
Old 08-20-2015 | 04:35 PM
Have you checked the cost of scat stroker kit's lately it's well very reasonable....You have good flowing alum heads easy to bump compression big power and torque in the cheap.
http://www.summitracing.com/parts/sca-1-91105/overview/
http://www.superchevy.com/how-to/pro...crate-engines/
Pliant is offline
Old 08-20-2015 | 04:41 PM
SB
Originally Posted by SAYWHAT
The other day went out on the boat had 4 adults and a full tank of gas 98 gallons on the boat GPS said 62 mph @ 4700 rpm it has 23 degree props is that normal and if so will they work with the upgraded engine.
Cool.
They may work with the upgraded motors. Either way, when the motors are done you put those on to baseline the set up.
A few boats I have out there, ended up running the same props but obviously at more rpm. But some of us have shed's full of props we keep for testing. LOL.
SB is offline
