Goodwin-Powered Outerlimits Upgraded with New Chartplotter, Engine Monitoring System >
Old 08-17-2015 | 09:33 AM
Jason Johnson's Avatar
Correspondent
Correspondent
Default Goodwin-Powered Outerlimits Upgraded with New Chartplotter, Engine Monitoring System
Northern Michigan's Peter Oppermann​ pulled off this cool project to be able to read data from his custom Goodwin engines on the new chartplotter he installed in his Outerlimits V-bottom.
http://speedonthewater.com/boat-rest...itoring-system
Jason Johnson is offline
Old 08-17-2015 | 09:57 AM
anyone interested in the noland upgrade feel free to ask questions here
drpete3 is offline
Old 08-17-2015 | 05:36 PM
What would it take for carbed blower motors?
Pokher Ace is offline
Old 08-18-2015 | 06:34 AM
Any electronic guage you have on your dash can be converted from analog to digital. The noland will do 6 gauges plus 2 tachs. If you want more than 6 just buy 2 units
drpete3 is offline
Old 08-18-2015 | 07:49 AM
You can also run it to any sensor without a gauge and get a reading on the noland. You do need to know the specs for the sender to calibrate the Noland for the correct range.
RT930turbo is offline
Old 08-18-2015 | 07:58 AM
If I read the article right doesn't it end up as a NEMA 2000 message?
It could interface with any NEMA 2000 compatible device then right?
Wildman_grafix is offline
Old 08-18-2015 | 08:27 AM
yes thats correct. I think this is a cool add on to any older or custom motor.
drpete3 is offline
Old 08-18-2015 | 11:31 AM
Are there in dash mounting options? Larger display options? Cool project Pete!
TCBoss302 is offline
Old 08-18-2015 | 11:41 AM
If I had a 12" display and 2 nplans boxes I could run 6 gauges each engine correct?
Unlimited jd is offline
Old 08-18-2015 | 12:04 PM
So lots of new chartplotters offer instrument display and are designed to plug and play with things like merc smart craft but I dont have smartcraft. The Noland RS11 takes an analog signal that your guages run on and converts it to NEMA 2000 that the new chartplotters can read. So Thomas just pick the brand and size chartplotter you want (make sure it can display instruments) and you can install iot anyway you want.
And Jd you are correct and with 2 units you can have 12 gauges and 2 tachs or 3 if you had trips.
I did oil pressure, oil temp and engine temp.
drpete3 is offline
