kiehaefer trim tabs fliud
Old 08-18-2015 | 07:14 PM
Default kiehaefer trim tabs fliud
i was looking thru some post as to what fluid for my kie trim tabs...thought it would be atf..........
BUT,,,,some people posted it was 10-40 motor oil!!!!!!!!!!!!!!!!!!!!!!
WRONG..
as stated on the instruction i have from 1989,,,states clearly use dextron atf only
.end of story.
flashgordon is offline
Old 08-20-2015 | 10:01 PM
phughes69's Avatar
ATF, SAE 30, motor oil, It all works the same. I would imagine that the atf works better because it has a lower viscosity. If it has dexron in it now, stick with it, but in the end any kind of motor oil or hydraulic type fluid will work.
phughes69 is offline
