need advice on electric fuel pumps
ran the cig couple times now .. it has holley electric pumps ... they run and make noise build pressure then all of a sudden running but no pressure .. its like they loose prime ... both pumps do it frustrating as hell one minute have 7 pds next drop to 0 . any sugestions .. thanks guys
No electric pumps like to draw fuel....the black/red/blue Holleys are amongst the worst offenders. They need to be mounted real, real low.....and then...they are still not without problems. There are better.....still mount the others as low as you can go.
Use anything but Holleys. I run SX pumps. I have injection, so not sure mine could go that low on pressure. But 10 seasons on them, zero issues.
I knew I was going efi but set my boat up to run on a carb first as I built my whipple motors.
