Hard to get on plane-NXTs >
Old 08-28-2015 | 02:43 PM
Default Hard to get on plane-NXTs
I have a 35' V with side by side NXT's my hole shot is horrible. I maybe over propped a little but on a lake I get full RPM range. NXT's have built in vents so I am wondering if additional vents or covering existing vents would help. I over speed engines frequently and have tried every drive and tab combo and multiple drive heights and in and out with props. Anyone with similar experience?
Thanks for any help. P.S. always enjoy reading these forums
Mad Props is offline
Old 08-28-2015 | 03:46 PM
hullofjustis's Avatar
Hard to get on plane as the props blow out or it lumbers and the bow stays in the air forever?
hullofjustis is offline
Old 09-01-2015 | 01:41 AM
Sounds like you need to do some prop testing. Call BBlades.
Griff is offline
Old 09-01-2015 | 07:34 AM
what props are you running bravo style or # 6 mercury or hering.
47 lightning is offline
Old 09-03-2015 | 09:15 PM
The boat feels like there is no props so I guess that's blow out. Bow up feathering to keep off rev limiters. The props are six drive clevers 37" 17 dia 19 rake.
Old 09-04-2015 | 09:07 AM
spinning in or out ?
Old 09-07-2015 | 05:56 PM
Spinning out and it is a little better spinning in but the over all handling is better out.
Old 09-08-2015 | 10:29 AM
you are over revving your engines? and it is hard to get on plane because the props blow out?
are you using a 4 or 5 blade prop? if you have tried drive heights try using a satin finish prop where polish finish is removed or sand the finished off the prop.
my x dimenson is too high on my boat and I actually can get on plane with my satin finish 4 blades vs my polished finished five blades.
Old 09-08-2015 | 10:35 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Are you using the tabs to get on plane?
An old raceboat trick:
Push the boat up until it just starts to blow out.
When it starts to blow out, chop the throttles back, and let the wake hit the back of the boat.
1) It will surf you up a little bit.
2) You now have a wall of water with the drives deep in such wall of water that you can apply power and and push the the boat all the way on plane.
--You won't get it right the first time. There is a timing/trial&error to it.
Sydwayz is offline
Old 09-09-2015 | 03:28 PM
The props are satin finish 5 blade cleavers.
I do use tabs about half down. More makes it worse. I will try the little push method this weekend. If I can have stiff wind at my back it helps quite a bit.
I am tempted to install prop aerators I would just hate to make it possibly worse.
