Bulldog cam problem >
Bulldog cam problem
Bulldog cam problem
Old 12-16-2015 | 10:14 AM
Default Bulldog cam problem
Hello,can anyone help with info on the cam for my Bulldog,the cam I have is a crane cam that was bought some years ago,don't have the original anymore. the problem is when its in place with the sprocket bolted on, the lobes are so far out of line that they are close to touching the adjacent lifter, the number on the cam(although very hard to read)is I think H240329 134802 the casting number for the engine block is GM 14044807.
MANY THANKS FOR ANY HELP WITH THIS.
ENGLAND DAVE is offline
Old 12-16-2015 | 11:00 AM
Do you have a cam card with that cam ? I looked it up and cant find any info on it
That should be a mark iv bowtie tall deck block. What timing are you using? Something seems off .
MILD THUNDER is offline
Old 12-16-2015 | 11:07 AM
if it is a flat tappet cam this is pretty normal,it helps in spinning the lifter in the bore so the face of the lifter doe,s not go flat and ruin the cam.
mike tkach is offline
Old 12-16-2015 | 12:49 PM
I thought the Bulldog's used the same cam as the carbed HP500 which would be a roller.
Griff is offline
Old 12-16-2015 | 01:04 PM
SB
In my notes;
Originally Posted by MarineKinetics
]The Merc Bulldog is an exceptional platform for upgrades. Many of these were contracted to the military, hence the overkill on the hard parts. Below are the specs on the engine.
541.9 CID
GM MK 4 tall deck (cast# 14044807)
Block clearance to accommodate 4.375” stroke
Siamese Bore, reinforced decks with blind head bolt holes.
Deck 10.2”
2 pc rear seal
Bore 4.44”
Stroke 4.375”
(With a factory recommended bore range 4.250’- 4.560” there is plenty of room for upgrades)
SCR 8.6:1
4340 Lunati crank
Piston is Wiseco (Merc part #)
Connecting rod is Manley +.400" / 6.535"
Dart Single Plane Intake Manifold
Crane Camshaft Specification Card
Part Number: 13H000036
Grind Number: H-240/329-2-10 T1.2
The cam rates on a 110*LSA, 5* advance
Lift .329” Lobe .559” Valve
Lift .340” Lobe .578” Valve
Specs:
@.0042"
................Opens..........Closes............. C/L...........Duration
Intake.....43.0 BTDC.....77.0 ABDC......105*..........300 °
Exhaust...88.0 BBDC.....42.0 ATDC......115*..........310 °
85* overlap
@.050"
................Opens...........Closes...........C/L.........Duration
Intake.....15.0 BTDC.....45.0 ABDC.....105*.........240 °
Exhaust...60.0 BBDC.....10.0 ATDC.....115*.........250 °
Camshaft Is Ground with .0012" Lobe Taper
Bob
SB is online now
Old 12-16-2015 | 02:19 PM
Is it a problem with the cam walking forward due to the cam button / retainer?
Budman II is offline
Old 12-16-2015 | 04:13 PM
Disregard that.
I think it was the same as the HP465 cam which was a flat tappet hyd
Griff is offline
Old 12-16-2015 | 04:58 PM
SB
Disregard that.
Yes, the cam info I quoted in my above post was used for both the 502/465hp and 540 Bulldog (500hp) motors.
SB is online now
Old 12-16-2015 | 05:02 PM
vintage chromoly's Avatar
The taper on the lobes will keep the cam in place. Roller cams need buttons as there is no taper.
vintage chromoly is offline
Old 12-16-2015 | 06:02 PM
Do you have a cam card for this camshaft with some specs on it? I can't find any info on that grind #.
