Picture of remote mount Procharger
Nice setup!
I assume this was done because of the limited clearance between the engine and back seat, correct? Did you notice any ill-effects of the extended ductwork and additional turns the airflow has to make compared to other comparable setups?
Exactly, there was no room to mount the intercooler. I have not noticed any ill effects, but then again I really don't have anything to compare it too. It did pick me up 14-15 mph and that seems to be the norm, so, I feel like everything is pretty efficient.
-Mark
-Mark
aaaargh...my chest...my left arm...
Seriously though, you had a real challenge sqeezing that in there, and you did a good job. You're right, you have nothing to compare your existing setup with, but if you're happy, leave it alone.
However...if you feel the urge to do a little cutting and welding this winter, let's talk. We'll do a little thinking "outside the duct". Those EFI systems are more of a challenge because of where the throttle body is placed, but I see a way to do it with no elbows. We would have to modify your intercooler housing, and make up a special discharge plenum and transition to the throttle body.
Make no mistake, ducts and elbows restrict flow. I just flow tested the Vortech carb box. The bare carb sitting in the box flowed ~1000 CFM @ 28"H2O. Put the lid on the box and add two 90s and one foot of 3.5" duct, the bare minimum needed to connect up with the compressor, and the flow drops to 643 CFM @ 28" H2O. That's before adding the intercooler which also restricts flow. Yes the compressor can overcome this resistance with more boost, and the intercooler can deal with the extra heat to a point, but the less elbows you have, the more air your compressor will flow at a given RPM.
There, I feel better now.
Tomcat,
Points well taken. That is very interesting information. What gains do think would be recognizable doing the modifications that you speak of?
-Mark
