350 mag mpi upgrades?
Old 03-13-2016 | 04:00 PM
Default 350 mag mpi upgrades?
Any upgrades for a 350 mag mpi that won't completely break my wallet or know where the best upgrades that are most bang for the buck. Also maybe looking to buy a used supercharger or pro charger, can't seem to find any. All help or suggestions appreciated please.
Rwgreen2384 is offline
Old 03-16-2016 | 12:48 PM
It's hard to give advice without a $$ amount attached. Everybody has a different threshold for "breaking the wallet".
Trash is offline
Old 03-16-2016 | 06:01 PM
BUP
what year 350 mag MPI
big difference with what you can do as far as to which ECM it is using for a stock Merc.
BUP is offline
Old 03-17-2016 | 08:51 AM
There isn't any thing that will make a significant gain on that engine without spending $$$. The best bang for the buck would be a Whipple. You can do the install in the boat in an afternoon. The kit comes with excellent instructions and has everything yout need. It's not exactly cheap, but in terms of hp per dollar it can't be beat.
HaxbySpeed is offline
Old 03-18-2016 | 10:20 AM
Assuming you don't have the 555 ECM, you can do just about anything you want IF you are willing to spend the money. As Haxby said a blower is one solution, but I'd also argue by the time you did all the plumbing and configuring for a Whipple you'd be in just as deep as a full engine rebuild with good parts and a stroker motor. Either route will get you a noticeable improvement in performance. I'd plan on $8,000 +/- a couple to get what you want.
Get the serial number of your motor as BUP suggested to see where your baseline motor is. Different years used different ECM which have varying degrees of 'tune-ability.'
Good luck.
Trash is offline
Old 03-18-2016 | 12:25 PM
BUP
Exactly what ECM - MEFI or triple nickle or PCM 09 or PCM 09 latest version ?
If I recall correctly Whipple does not reflash MEFI but I might be wrong about that one.
BUP is offline
Old 07-10-2016 | 09:16 PM
I just found this thread, I also am interested in upgrades. not to hi jack, but how can I find out what ecm I have. The motor
is a 30 hour jasper marine 330 hp 350 MPI Mag engine.
Donzi Z22 is offline
Old 07-11-2016 | 04:40 AM
On the back of the ECM is a serial/part number. From there you can determine if its MEFI 1, 2, 3 4a, 4b, 555 etc.
That and a picture and we can direct you further.
Trash is offline
Old 07-11-2016 | 08:44 AM
Having built a pair of 6.2s, I can reliably say there isn't a damn thing you can do "without breaking the wallet."
This isn't like modding cars where you can slap on a pair of long tube headers and pick up a noticeable amount of horsepower.
Captain YARRR is offline
Old 07-11-2016 | 03:42 PM
I'd echo Capt YARRRs statement but emphasize the word "noticeable". It takes a bunch of work to make any significant or 'noticeable' performance improvements.
Trash is offline
