Map sensor  502 Mag MPI >
Old 03-21-2016 | 07:11 AM
Smitty's Avatar
Default Map sensor 502 Mag MPI
Anybody ever replace one with an automotive one ? Merc wants $ 165.00 where as one from Napa is like $ 45.00 I think it is a 1 bar ??? Just guessing.
Thx
Smitty is offline
Old 03-21-2016 | 07:45 AM
articfriends's Avatar
Buy a 1 bar replacement for 88 to 95 chevy 1/2 ton tbi 5.7 at autoparts store
articfriends is offline
Old 03-21-2016 | 08:36 AM
Smitty's Avatar
Perfect. Thank you !!
Smitty is offline
Old 03-23-2016 | 08:26 AM
Good to hear..
Pismo10 is offline
Old 03-23-2016 | 10:42 AM
BUP
It is wise to check with a scan tool your MAP readings after changing from one to another brand maker. MAP sensors all are not created equal and the same goes for IAC's - when buying from different manus but still is the same part. I have tested this with the scan tool as well and the readings can be different. Sensors come into play alot when it comes to air & fuel delivery, throttle response and idle quality .
MAP sensors 2 bar for SC engines for low to mild boost
1 bar for NA engines
BUP is offline
Old 03-23-2016 | 12:15 PM
Originally Posted by BUP
It is wise to check with a scan tool your MAP readings after changing from one to another brand maker. MAP sensors all are not created equal and the same goes for IAC's - when buying from different manus but still is the same part. I have tested this the scan tool as well and the reading can be different. Sensors come into play alot when it comes to air & fuel delivery, throttle response and idle quality .
I believe there is some way to tune or calibrate the new sensor(s) ?. I just can't think of it off the top of my head.
92nsx is offline
