Has anyone made boat stands or have plans for making them? >
Old 03-23-2016 | 12:39 PM
Default Has anyone made boat stands or have plans for making them?
Just wondering if anyone has ever made boat stands that can be used for the corners of the boat? I want to take my boat off the trailer and I was hoping I could fabricate some stands. I do have a mig welder and I would want them to be adjustable. Like the adjustable screw jack kind.
FBRONCO is offline
Old 03-23-2016 | 03:14 PM
Everybody i know stacks cement blocks...you could maybe find a nearby boatyard and rent-borrow a couple for a time. Lots of boats are coming off their stands next few weeks.
dereknkathy is offline
Old 03-23-2016 | 03:55 PM
jwp
[ATTACH=CONFIG]552816[/ATTACH] scaffold swivel base would give the screw you're looking for
Attached Thumbnails Has anyone made boat stands or have plans for making them?-bpsjaset-2.jpg
jwp is offline
Old 03-23-2016 | 06:10 PM
good idea. Hopefully someone will have plans.
FBRONCO is offline
Old 03-23-2016 | 06:14 PM
weldcrane's Avatar
Brownell boat stands !!!
There made in mass
weldcrane is offline
Old 03-23-2016 | 09:04 PM
There are several DIY boat stand videos on You Tube
partlowr is offline
Old 03-24-2016 | 07:12 AM
....Why go to the time and trouble to make them when used ones are everywhere..................M.O.
motor is offline
Old 03-24-2016 | 09:35 AM
I'd probably use these. They're cheap at ~$90/ea for the 3500# model.
http://www.sumner.com/sumner/sub/pro....9.27.0.0.html
Cole2534 is offline
Old 03-24-2016 | 10:40 AM
I have made them with the swivel scaffold legs that jsp posted.
I took normal car jack stands and cut them right at the top of the taper. Then I welded in a piece of chromoly tubing that the scaffolding legs slide into. Then I just put a piece of wood or thick rubber in between the stand and the hull. I have them at home and will take a picture when I get there after work.
DBleil89 is offline
Old 03-24-2016 | 11:02 AM
vintage chromoly's Avatar
Just say no to CMU blocks for use as "jack stands" in any application! Great way to get yourself seriously injured or killed.
vintage chromoly is offline
