Can a 2009 Escalade pull a 1999 36ft Baja SST? >
Old 04-10-2016 | 06:36 PM
Default Can a 2009 Escalade pull a 1999 36ft Baja SST?
I have looked and my towing capacity is 8300lb and the boat is 8300lb, however I know that doesn't include gear or gas or trailer, I won't tow over 70 miles at a time and usually less then 10 miles.
Joentuff is offline
Old 04-10-2016 | 06:46 PM
It will pull it, but will it stop it when a soccer mom pulls out in front of you distracted by her screaming kids in the back seat?? And then when your insurance company laughs at you as the family of the deceased sue you for millions...
phragle is offline
Old 04-10-2016 | 06:50 PM
It has the 2500 frame and brakes, also I have trailer brakes.
Joentuff is offline
Old 04-10-2016 | 06:59 PM
Registered User
I used to have an Escalade and I wouldn't want to tow that weight very far. Maybe a couple miles or so but not 70. It Def has the power to pull it but thats a lot of weight.
Nastybug is offline
Old 04-10-2016 | 07:13 PM
Short answer is NO
hotjava66 is offline
Old 04-10-2016 | 07:17 PM
a 2500 will be fine. put e/h brakes on all the axles
class6 is offline
Old 04-10-2016 | 08:53 PM
obnoxus's Avatar
Charter Member #1171
its 12,600 lbs on the trailer......I wouldnt !!!
Even my 2500 with a 6.0 gas struggled.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 04-10-2016 | 08:59 PM
Expensive Date's Avatar
No
Expensive Date is offline
Old 04-10-2016 | 09:08 PM
Revspan's Avatar
The Escalade is not built on a 2500 chassis. It has the 6.2l gas engine, but coil suspension in rear. This is not the truck to pull that size boat.
Revspan is offline
Old 04-10-2016 | 09:12 PM
Not true. All 1/2 ton running gear.
wfo1 is offline
