Top speed on 2000 Outlaw 25 496HO
Just bought a 2000 Outlaw 25 with a 496 HO. I had read a lot about the boat before and have seen everywhere this boat does 65+ mph without any mods. Mine however, does about 61-62 with a best ever of 62.6 on GPS. The prop being used is a 4 blade Bravo 1 26P Stainless Steel.
At WOT, the engine runs at 4800 rpm.
Any input from anyone with experience with this boat will be greatly appreciated. Thanks
Haven't owned a 25OL but I think a 26P Brovo 1 prop is a bit tall for the 496HO. You should be closer to 5000 rpm at WOT. My last boat was 25 Citation with a 496HO and before the CMI elbow top headers it had a 22P Bravo 1 prop spinning at 5000 rpm. After the headers I spun a labbed 24P Bravo 1 at 5000 - 5050 rpm. I was experimenting with a 26P Bravo 1 right before I sold the boat and it was just too much prop for that engine with a 1.50 Bravo X.
Your close tho at 4800 rpm so maybe some lab work on that prop can get you there.
I have a 2003 25 outlaw with the same engine. It has the stock 3 blade prop. I'm not sure of the pitch, think it's 23. Boat runs in the high 60's, around 68 in good conditions. Could be your prop.
I read that 1 pitch translates into 200 rpm and so if I run at 4800 rpm with a pitch 26 going down to a 23 would raise the rpm at wot by 600 and bring me up to 5400?? But since I am told that a 3 blade 23 is the stock prop it confuses me a little bit
You'll probably never get to 5400, rev limiter on a stocker is 5150rpm, I believe. That 200rpm/1" pitch is a general rule of thumb, not law. Cup, rake, blade surface and diameter all come into play.
