What the Puck to do about Lavorsi's GPS Antenna? >
Old 05-17-2016 | 12:41 PM
Default What the Puck to do about Lavorsi's GPS Antenna?
Apparently if you have an older style Gaffrig/Lavorsi Speedo (or three as in my case) with a battery powered puck-style antenna and your battery is dead - you are now pucked. Lavorsi doesn't sell replacement antennas and now they no longer offer a replacement service for your battery. Apparently you can't just change the battery yourself because according to Lavorsi the antenna requires a software reboot after the battery has been changed. The new Lavorsi solution: buy a completely new gauge and antenna from Lavorsi for over $550 instead of just replacing your battery.
Does anyone know a way around this?
Attached Thumbnails What the Puck to do about Lavorsi's GPS Antenna?-img_0024.jpg
Marginmn is offline
Old 05-17-2016 | 01:02 PM
You can replace your antenna with one that has the same type of wires as the depleted one.
Taboma is offline
Old 05-17-2016 | 01:04 PM
Great, where can you buy them?
Marginmn is offline
Old 05-17-2016 | 01:14 PM
I'd tell Livorsi to go puck themselves with sand for lube.
Wasted Income is offline
Old 05-17-2016 | 01:20 PM
1 MAIDEN AMERICA's Avatar
I don't remember what puck(looks like a computer mouse) I have but I replaced the battery and it worked afterwards. I had to unsolder a tin cover to get to the battery, then unsolder the battery. The replacement battery was a little different (connectors) but I was able to tweak them and get it to work. That was 5 years ago now. Still works.
1 MAIDEN AMERICA is offline
Old 05-17-2016 | 01:22 PM
Exactly. You literally have nothing to lose by trying your own battery replacement.
SB
Not sure this helps, just in case your phone person told you incorrect info. This will help you double check:
http://www.livorsi.com/auto/pdf/gps_...placements.pdf
SB is online now
Old 05-17-2016 | 01:24 PM
Bill 3's Avatar
The Garmin GPS 18x PC will work. This is what I used.
Bill 3 is offline
Old 05-17-2016 | 01:29 PM
SB
Okay, some quick and unique searching go to me to a good thread on Scream and Fly, and itlooks like a guy there can fix them. You can read whole thread, but below link get's you to the meat faster. His screen name is luv2gofast.
Link: http://www.screamandfly.com/showthre...-replace/page4
SB is online now
Old 05-17-2016 | 01:32 PM
SB
Ooops, missed this ^^^^. From the link I provided above, they seem to mention this also.
SB is online now
