Holley electric fuel pump
Old 07-04-2016 | 05:30 PM
Default Holley electric fuel pump
I have a 454 mag, 385 h.p. Holley 750 double pumper. I am using a Holley Black electric fuel pump. It went bad the other day and i am looking to replace with another Holley pump. I see they have 2 others besides the Black. The Red and the Blue. I know the Red pumps the lowest amount of fuel, then the Blue. Just wondering if i could use either the Red or Blue, besides the Black which seems to be an over kill in my opinion. Any advice would be greatly appreciate. Dan
Baja 240 sport is offline
Old 07-04-2016 | 08:11 PM
Personally, I wouldn't use any of those holley electric pumps.
MILD THUNDER is offline
Old 07-04-2016 | 09:04 PM
ROB FREEMAN's Avatar
had nothing but problems with the holley pumps in the cig , replumbed my eikert upgrade seawater fuel pumps . haven't had a problem since good riddens
ROB FREEMAN is offline
Old 07-04-2016 | 10:13 PM
Rookie's Avatar
I have been running Mallory 140's for years. Look at the Mallory 110. They are easily rebuild able and internally regulated at 7lbs.
Rookie is offline
Old 07-05-2016 | 05:13 PM
Thanks for the advice
Old 07-05-2016 | 05:14 PM
Thanks, for the advice. i appreciated
Old 07-05-2016 | 05:15 PM
Thanks i will look into that.
Old 07-05-2016 | 09:46 PM
Those mallory pumps are pretty darn reliable pumps. Is there a provision for a mechanical fuel pump on your engine ?
Old 07-06-2016 | 04:06 AM
Here on the site, they suggest an aeromotive fuel pump with my application and it has worked great
conneroutlaw is offline
Old 07-06-2016 | 02:45 PM
Thanks for the response. There is no provision for a mechanical pump, can only use electric. I used the Holley Black pump that was installed 9 yrs.and it worked fine. Need a new pump , but thought something like the Black pump was over kill for my motor and carb setup. Now just looking what will work best. Thanks again.
