Small block ignition
Putting an aluminum head small block together. Will be na, 10.25 compression or so. Will stock ignition hold?
If not what else is recommended? I don't want to be a boat that has to keep extra ignition boxes onboard. F MSD.
Yes, to 6200+rpm with an MSD HVC canister coil. Not sure if stock coil will do it.
Make sure your cam has an iron gear to be compatible with the TBIV distributor.
If you want to change timing curves, that poart is harder, but better to soend the $500-$600 on a Daytona Sensors marine box (will work with the tbolt IV system) vs a full MSD system.
