Go Back  Offshoreonly.com > Owners Forum > Powerquest
No trim tabs on boat ????? >
Old 09-30-2002 | 02:03 PM
MATTT
Default No trim tabs on boat ?????
Hello, everyone.
I saw a 2000 237 Striker forsale today. The boat only has 50hrs on it with a 454 bravo one, 310 horse. The asking price is $36,900. The boat looks nice and all, but it does not have trim-tabs on the boat. Isn't that odds ? Why would some one order a boat with no trim tabs. Would I need a trim tabs for a boat that size and that engine ? It doesn't have carpet where the cockpit at also. Do you think that is a good price ?
Thank you for the info,
Mattt.
Old 09-30-2002 | 03:09 PM
DaveHam's Avatar
I had a 23ft Cobalt with a 330hp 454 and no trim tabs and it handled fine.
DaveHam
DaveHam is offline
Old 09-30-2002 | 07:39 PM
rbtnt's Avatar
I had a 260 without trim tabs and I never put my carpet in the last 2 years unless it was real cold out.
rbtnt is offline
Old 10-01-2002 | 06:25 AM
Jan's Avatar
Jan
Member "69" Charter #70
No TABS on my 260, Boat Just does not need them. Always will pop on plane with 2, 3, or 4 onboard.
Jan
Jan is offline
Old 10-01-2002 | 11:47 AM
wms
I would think you could almost buy a brand new one for that. Keep looking!
You should not need trim tabs on a 23' boat. My 232 ran fine without 'em. I rarely used them on my 272.
Old 10-01-2002 | 12:28 PM
MATTT
Thanks, every one for the reply.
I thought the price was high for that year. No trim tabs, so is it just for looks ? What purpose does it surve ?
Thanks again, every one.
Mattt.
Old 10-01-2002 | 01:20 PM
My 260 didn't have them, but I added a set of Bennett 12x16 dual ram sport tabs with Stainless Marine mechanical indicators. The boat didn't need them as far as getting on plane or handling. But I do like having them to counter the port side lean and in rough water I put the tabs down a little and keep the drive parallel with the bottom. I prefer this to tucking the drive under to keep the bow down in rough water. I boat in mostly rough stuff. Also at wide open throttle the boat used too chine walk a little bit, it doesn't do it at all now. The cost was $750 and a weekend of my time to put it all on. I think it was worth it. You should be able to get a 260 with a trailer for that price.
Gary C is offline
Old 10-09-2002 | 10:15 PM
MACDAD260's Avatar
Charter Member #818
If you do any boating on rough water trim tabs are very nice to have. You will not want to do without them once you have used them. I see a lot of PQs sold without tabs. I think it is just to keep the cost down but, in my opinion they are not a luxury item. If you see a boat you want to buy that does not have tabs, use that as a bargaining tool to get a better price. You can always put them on later if you like everything else about the boat.
MACDAD260 is offline
26sonic
Sonic
8
06-23-2009 09:14 PM
dloftis
Baja
8
03-12-2009 08:08 AM
Strip Poker 388
11
03-22-2006 01:51 PM
jvschlegel
11
09-22-2005 10:25 AM
tech54
Active Thunder
2
10-08-2003 07:43 AM
