Torsion Axle Articulation
Old 08-12-2016 | 10:37 AM
BDiggity's Avatar
Default Torsion Axle Articulation
We are replacing the leaf axles with Dexter #11 Torflex axles. I am trying to understand the start angle i need to order. I was looking at an unloaded Myco, & it looked like it had maybe a +10deg angle. Besides maybe fender height issues, is there any advantage/disadvantage to the the different angles; -45, -22.5, -10, 0, +10, +22.5 ?
BDiggity is offline
Old 08-13-2016 | 04:39 AM
I don't know the exact answer but having owned several tortion axle trailers I would say 22.5 if I had to guess. Are you converting a steel or aluminum trailer?
ezrizer is offline
Old 08-13-2016 | 09:50 AM
BDiggity's Avatar
It is a steel trailer, & for the most part pretty much a complete new build. i wasn't sure if for ride quality, etc if a certain degree was better than another.
BDiggity is offline
Old 08-13-2016 | 07:22 PM
I don't know either I'll do some research and post anything I find relevant. I was thinking how a conversion would work on my Myco. I'd have to build some kind of spacer to make up for the springs or raise the fenders. Post some pics if you go through with it.
ezrizer is offline
Old 08-14-2016 | 03:28 PM
weldcrane's Avatar
Go to Redneck trailer they have all the angles and dimensions you need to hell you figure it out !!!
weldcrane is offline
Old 08-15-2016 | 08:50 AM
BDiggity's Avatar
Yeah they have a great site, that's where i have been gathering all my info. I think i have everything i need to place the order except my hub face measurement. So going to have to figure out way to get this from the current trailer.
BDiggity is offline
Old 08-20-2016 | 09:14 PM
BDiggity's Avatar
I spoke with Dexter & the guy told me if i want ride height to remain the same as does now with leaf springs, to go with 22.5 down.
Here is where i will be posting pics of the build
http://www.offshoreonly.com/forums/c...e-resto-6.html
BDiggity is offline
Old 08-20-2016 | 11:41 PM
Rookie's Avatar
Yes, 22.5* When I switched to custom 6000# torsion axles, this was the best pricing I found on axles. 2 drop shipped for $120.
http://www.ebay.com/itm/New-6000LB-D...tSxxMl&vxp=mtr
http://www.offshoreonly.com/forums/t...ler-axles.html
Rookie is offline
